A little help please.. error codes? Mechatronics? Or something else?
  • A little help please.. error codes? Mechatronics? Or something else?
    Hey everyone, I have a Golf mk6 2013 1.4l.
    I have it booked in to be fixed this week, but am hoping to get advice first.
    It’s having issues with the transmission where it goes into limp mode within the first few kms (the car loses all power and needs to be restarted) and then I can restart the car and it drives fine, though sometimes it does it multiple times.
    It has a few error codes which I’m trying to decifer what the issue may be. I was told it’s potentially the mechatronics, but would like some advice here before replacing it. Do these codes point towards the mechatronics needing replacement or could it also be something else. I don’t want to replace it unnecessarily.
    The error codes are as follows
    Transmission:
    002113 - transmission fluid pressure sensor /switch 1 - P0481
    006293 - functional restriction due to pressure drop - P1895
    006300 - functional restriction due to pressure build up - P189c
    006079 - hydraulic pump P17bf
    Any advice or hints would be great.
    There’s also engine codes:
    7021 - MIL request signal active p1624
    4172 - manifold pressure / boost sensor
    Thanks heaps for any advice 👌🏼
