So I've got the ever so reliable GOLF CAVD engine with a DSG and 80% of the time it's great. However 20% of the time it decides it won't rev over 3000rpm in any given gear. It's quite annoying when trying to overtake and realising you've got no power as soon as the turbo spools up. Anyone know of this issue, there's no engine codes or warning lights popping up when it happens either.
MK6 118TSI 2010 3000 rpm Rev Limit
Have a look here, someone with the same car with the same issue. Looks like an issue with the transition from supercharger to turbo causing the issue. The flap or clutch which transitions from the supercharger to the turbo failing.
Engine holds 3,000 RPM randomly...
Volkswagen Golf tsi - Won't go over 3000rpm limp mode ?. Hi last night had major issue with my golf heading up slip road put foot down got to 3000rpm would not go any more than 3000rpm in any gear could not hear the supercharger like a usually could I ended up with a fault code p10a4 n went digging thro google etc also noticed that they recommend you use a high octane fuel higher than 95 Ron not sure if this is what caused problem by time got home the engine management light had came on but next day it had gone car was back to normal anyone else had issues like this I phone vw with fault code they never knew what it was on hours of searching google someone said about supercharger flap failing ??? Any info would be great
