whey guys
a mate of mine had catastrophic turbo failure on a 42celsius day on the highway, broken turbo shaft...
he had just had 5w-30 penrite enviro put in with new filter a few days earlier... car only has 70k km on the clock, had both of the recalls attended to ? presumably the software stuff in 2013 and another recall in jan 2018 ...
I am new to this engine but am gonna help out by swapping in a new CHRA I think the housings are ok enough. there is some compressor wheel debris that I hope has only made it as far as the intercooler which I will empty out and I will also check and clean the turbo inlet and return oil lines to make sure they're ok.. i'll cut open the oil filter and check for debris from the crank in case the oil pressure loss or perhaps the hot 42c day caused oil breakdown and lunched the whole motor..
Anyone else had turbo failures likes this at low mileage... ??
maybe a lot of city driving or hot shutdowns or a lot of idling or maybe it wsa turbine side heat stress from the lean engine problem i've read about ? dunno
heres a vid for your entertainment
YouTube
Addit: i've just read a few threads where people talk about the extended oil change intervals being to blame, they did a road test for 60k km with VW recommended service intervals then pulled the engine down and the turbo was damaged from excessive deposit formation due to oil breakdown and high temps
YouTube
