Hi Guys,
My '09 MK5 Golf GTi developed an unusual fault two days ago. When I indicate (Three flash lane change) to turn, my high beam comes on for a few seconds, the right indicator flashes three times, then the left indicator flashes three times. It doesn't matter which way I attempt to turn, I get the same outcome.
If I move the indicator fully into the on position, the High beam comes on and stays on until I re-centre it. The same pattern of indicator flashes is repeated. If I turn the indicator on when the ignition is on, but, motor not running, the high beam comes on and stays on.
Any ideas what is going on here?
PS. I have a Stage 1 ECU and DSG tune done in March '17. I get the occasional intermittent Engine Warning light which disappears after a couple of days. This light came on Saturday night and is still on. The indicator trouble started the following Monday night.
Thanks for any advice you can give me.
VWBoomer.
VWBoomer.
