when my car breaks traction it axle tramps really bad.. mostly on rough surfaces.. will those torque arm or engine mount inserts help this? or should i be looking at a particular suspension setup?
1 of 2
2 of 2
how to stop axle tramping wheel hopping?
Originally posted by chrisgti View Postwhen my car breaks traction it axle tramps really bad.. mostly on rough surfaces.. will those torque arm or engine mount inserts help this? or should i be looking at a particular suspension setup?
Dave
moderation of the right foot helps a lot yes. But in the MK5 the axle tramp is particularly violent! torque arm inserts are supposed to help dramatically. Ill be installing mine early next month so will see how it goes
FOLLOW US ON FACEBOOK
Is the axle tramp caused by ESP modulating power?
I get it with ESP on, but not a great deal with ESP off (which is quite rare).
Either way, it's a 'kin awful sound.
If you have a lazy 3 or 4 grand lying about, you could investigate a LSD...2007 Golf GT | DSG | TR | roof | iPod rubbish | R line fog grilles | R satin mirror caps | R pedals | R console trim | colour coded GTI valences | R32 Ormanyts
Originally posted by tinto View PostIs the axle tramp caused by ESP modulating power?
Definately fit a torque arm insert. Its a great thing for sopping that tramping feeling. You wont regret it.
AndrewPar 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
The APR hard nylon insert for about $100 for the lower bush is both quite simple and makes a noticable difference. If you still launch really hard it will still hop, but you can launch at 4/5 without hop whereas before it was lower. When it does hop, it's less violent too. From here, the cost of improvement increases a LOT. I agree with the other posters, learning some launch control is the biggest help!Last edited by Greg Roles; 21-07-2008, 09:04 AM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
