how to stop axle tramping wheel hopping?
  • how to stop axle tramping wheel hopping?
    when my car breaks traction it axle tramps really bad.. mostly on rough surfaces.. will those torque arm or engine mount inserts help this? or should i be looking at a particular suspension setup?
    Just a suggestion ... take the lead out of your right boot a little. Helps wonderously.
    Dave
      moderation of the right foot helps a lot yes. But in the MK5 the axle tramp is particularly violent! torque arm inserts are supposed to help dramatically. Ill be installing mine early next month so will see how it goes
      FOLLOW US ON FACEBOOK
        All of the above, but they go up in price in the order you have listed them.
          Is the axle tramp caused by ESP modulating power?
          I get it with ESP on, but not a great deal with ESP off (which is quite rare).
          Either way, it's a 'kin awful sound.
            If you have a lazy 3 or 4 grand lying about, you could investigate a LSD...
            2007 Golf GT | DSG | TR | roof | iPod rubbish | R line fog grilles | R satin mirror caps | R pedals | R console trim | colour coded GTI valences | R32 Ormanyts
              Its more when you break traction and regain it. That it probably why it happens more with ESP on.
                Definately fit a torque arm insert. Its a great thing for sopping that tramping feeling. You wont regret it.
                Andrew
                  The APR hard nylon insert for about $100 for the lower bush is both quite simple and makes a noticable difference. If you still launch really hard it will still hop, but you can launch at 4/5 without hop whereas before it was lower. When it does hop, it's less violent too. From here, the cost of improvement increases a LOT. I agree with the other posters, learning some launch control is the biggest help!
                    Get suspension. That will eliminate it completely unless ur flogging it in the rain.
                    Also tyres play a big part.
                      Cheers guys guess i'll be getting myself one of those inserts, that banging just isnt cool
