I have read heaps of guides and watched the You tube videos on how to set up Rain closing via VCDS.
I just cannot work it out.
My car is early model so do not have the newer BCM module, has the Bordnetz. I should be making changes in 46 Central Conv AND 09- Cent Elect.
VW Golf/Jetta/Bora (1K/5M) Tweaks - Ross-Tech Wiki
The 09- Cent Elect part is fine: Long Coding, Byte 0, Bit 2 Rain Closing Active
But 46- Comfort System module, Long Coding Rain Closing" option is just not there.
Most guides show a 19 byte code but as you can see mine is only 14 bytes
Some details on the Central Conv module
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00D802087F2D8405485FC69011A0
Shop #: WSC 80090 959 67746
VCID: 79FE75CB30CAF5F61A-802C
Has anyone found the same, how did you get it to work. Or am I just out of luck on this one ?
Component: KSG 0401
