After recently having my 2007 DSG serviced, I was hoping that replacing the filter housing and O-ring would solve the oil leak on top of the transmission housing.
Not the case, with a fresh leak coming from what appears to be the oil cooler.
I know the Oil cooler O-rings were replaced previously before my time in an attempt to stop this leak, which hasn't worked.
so what is my next move? Replace the O-rings again, or can a leak be coming from the cooler itself anywhere? From quite a bit of searching most references to a leak seem to refer to the oil filter housing O-ring or the cooler o-rings. So i'm a little stumped.
