Hi all,
I was driving this afternoon and the engine suddenly went dead. MFD, speedo and tacho all went off. Power steering and brakes appeared to be dead also. However the radio was still on. It was as if I turned the ignition off.
There was no engine light or any sort of warnings at all.
I pulled over, turned the key on/off a few times but it didn't work and nothing appeared on the MFD. Opened the door, the MFD came up with the door opening picture. Closed the door, turned the car on again and it started.
I drove for another 30 seconds, then the same problem happened again! NRMA tech came out and couldn't find any problem. He checked the fuse, oil, error code (he has a portable scanner thingo), battery....could not find any problem. The car died on him a few times while he was checking as well. Eventually the car decided to stay running and we got home safely with the NRMA tech following us.
NRMA tech said one of his mates had seen similar issue before it was due to faulty unit behind the instrument cluster.
Has anyone experienced this issue before? or has any ideas/suggestions? I will definitely get it checked in a workshop as this is dangerous and major issue, but I would like to get some ideas of what might be the cause.
Notes
* The engine was running fine and smoothly. No struggling or anything like that. It went dead quietly as if I turned the car off. MFD also had no display.
* Engine does struggle a bit from a cold start normally.
* 2 months old battery
* 2 months old PCV
* Car has done 132,000KM. Major service done.
* It's manual so shouldn't be affected by the recall (apparently for DSG only?)
Thank you in advance for your help.
A
Notes
* 2 months old PCV
A
