Hi All
I am about to do a 120,000 service on my GTI and just want to check that I have everything covered.
I plan to replace:
- Engine Oil
- Oil Filter
- Air Cleaner Element
- Pollen Filter
- Fuel Filter
- Spark Plugs
Additionally, as part of this service I will be replacing;
- Coil Set
- Manual Transmission Fluid
I previously had replaced at 105K: timing belt, water pump, PCV valve and fuel pump cam follower.
My questions are:
- Are there any other items that I need to replace/tune/adjust at 120k service? The service schedule in the manual isn't real clear.
- Do the OEM spark plugs need the gap adjusted or are they ok out of the box? What is the gap spec? P/N is 06H905621.
- Any other tips that I need to consider/be wary of during this service?
Thanks.
I plan to replace:
- Engine Oil
- Oil Filter
- Pollen Filter
- Fuel Filter
- Spark Plugs
- Coil Set
My questions are:
Thanks.
