Rear Disk Brake size and part numbers
  • Rear Disk Brake size and part numbers
    Hi all,
    About to replace my rear break pads on a 2005 Golf 1.9 TDI
    Anybody know correct pads including part numbers.
    Any recommendations for pads and disk suppliers would also be welcome.
    I am in Brisbane. Called Burson's they only had the cube break piston tool so i ordered a compression twist tool for ABS breaks from another supplier.
    Trumper.
    Just found this on the Bendix website not very helpful. WIll i have to pull the wheel off to find out the disk size on the rear?
      look up the brake code on the build matrix inside the service book.
      It should be...
      On the front:
      280x22mm (vehicles with option codes 1ZC,1ZF,1ZM)
      288x25mm (vehicles with option code 1ZE)
      312x25mm (vehicles with option codes 1LJ,1LL)
      On the rear:
      255x10mm (vehicles with option codes 1KD,1KQ)
      260x12mm (vehicles with option codes 1KE,1KF)
      286x12mm (vehicles with option codes 1KJ,1KY,1KZ)
      Failing that, ring Brakes Direct (forum sponsor)
        If it's got the original discs on it, it'll have the part number stamped in the outer edge of the 'hat'.
          Volkswagen - GOLF - 2008 Golf - Wheels, Brakes Teile Katalog (Pats Catalog)
