Hello...
So I've just received a phone call from my mechanic and it was not what I wanted to hear at this time of the year...
Symptoms - rough idle, loss of power, engine light on
Diagnosis - ran a diagnostic and got the dreaded P0304 (misfire in cylinder 4) and P0030 (O2 sensor error/failure) & compression test
Treatment - change spark plug & change ignition coil
Result - Slight improvement, but still rough idle, engine light came back on after clearing
Other theories - Stuck valve, worn cam lobe, stuffed piston (possibly - worst case)
Mechanic's advice - either open it up and see what the problem is or a replacement engine
Anyone got a spare 1.4 tsi motor? or know if anyone is selling on
