AirCon/Heater flip flip flip, click click glove box area
  • AirCon/Heater flip flip flip, click click glove box area
    Hey all,
    Did a bit of research on this, basically there were 2 responses:
    Fuel lines flapping against firewall - is an issue that was resolved apparently in a service release?
    Recirculation valve of some sort in the AC/Heater system behind glove box area.
    So I switched off the AC/heater and there was no noise, back on and its usually consistent to idling at the lights and not rhythmic, so different every time. Assume culprit is the Ac/heater unit with flappy valve issue or something along those lines. Flap flap, click click click pause........ flap click.
    Anyone got any info on this and if I should just ignore it?
    Cheers,
    Cheddo.
    2006 MKV GTI - Silver / 6spd / APR S1 / Sunroof / 7" LCD GPS Android JB 4.1 Head Unit
    Climatronic?
    Is it quiet, as in you can only just hear it?
    If so, it's the blend flap adjusting to maintain your chosen temperature.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Yeah quite noticeable when sitting at lights on idle, don't usually have much MP3/radio volume when wife and mini me is with me, this is when I notice the most.
        Could be worth trying a basic set on it.
        '01 Beetle 2.0
          I get the same noise. It is quite annoying, but can't think of what I am doing to make the sound
          Although it sounds it goes off at random intervals, I'm sure there is some commonality to ot
            Change temperature.
            '01 Beetle 2.0
              A basic set?
              As it is quite cold in VIC atm, common setup is AC on, dual zone set to 22 deg, recirculate to on or off doesn't seem to make any difference.
                What Umai said. I notice the flaps in nearly every climatronic car.
                The knocking is the motor reaching its end stop
                A basic set may or may not fix it
                  Sorry, asked this before also - what is a basic set?
                    Bascially, through a combination of button-pressing, you can run it through a re-learn procedure that will re-calculate all the end-positions of the flap motors.
                    How to reset and calibrate HVAC flaps in VW Climatronic (Golf, Passat, Jetta, Scirocco, Touran) - YouTube
                    https://www.youtube.com/watch?v=h9lqvjg8wOY
                    '01 Beetle 2.0
                      You sir are a champ - will try this tomorrow.
                      Cheers,
                      Cheddo.
                        I have been wondering what the noise has been for the past few months, guessed it was just something adjusting itself electronically.
                        Will also give the reset a go tomorrow and see if it resolves the tapping
                          Keep us posted if it fixes it as my wife's golf does this aswel.
                          Sent from my windows 8.1 phone via tapatalk
                            OK did the reset as per the YouTube vid, did it's thing for about 3 minutes, then same same.
                            No change.
                            Click Click Flap Flap Flap.....
                              Yep same here, no change since
                              Sent from my iPad using Tapatalk HD
