Hi Guys,
I assume this will be the same problem as some of the other guys have been having with the n75 valve for the GT Sport 1.4 twincharger engine, but I thought I would ask just to see if there is anything I should be looking at.
Anywho, my GT Sport has just had it's second major service (120000km) completed, after which the car has started shunting when under load, but not at the 3500rpm point that most people complain about. It does seem to happen less when the car is cold.
I took it back to the place that did the service a couple of days later and they said they had seen this before and said the turbo was faulty and would need replacing (all $3000 of it), which is why I want to know if there is anything else that needs to be looked at. There was an issue leading up to this service that I was getting a constant error for in the VCDS logs in regards to the n80 valve, which turned out to be faulty wiring.
This had happened once before around the time of the first major service, which I thought was spark plugs because the dealer failed to recognise that they did not have the required spark plugs in stock and did not "get them in stock" till 3 weeks later after I called them a few times, but after the spark plugs being replaced, this problem went away until now.
Any advice that people can shed on this would be greatly appreciated.
