What 2.0T are you revving to 8000rpm? I think you hold the world record by a very large amount if you achieve that.
We can hold 30 - 35PSI to redline (which all three of our stage 3+ cars have) with the stock DV there is no "cracking open".
I'm happy to put my money where my mouth is - prove any of the above with data, and I'll switch all our cars instantly over to them. Your are welcome to use our dyno to show us (you can even choose the car), and I'll allocate you a tech - you can even run the dyno yourself.
If you understand how the stock DV works, you would think twice about it. I suppose the same could be said for requiring a boost controller on cars struggling to make 250kws at the wheels where we use the factory ECU boost control & N75 on cars running in excess of 300kw's at the wheels - its understanding why VW designed the product the way it is..
The "Light Throttle" driveability is in the mapping, not the DV. Once again, anyone is welcome to test drive any of our demonstrator cars & test the "light throttle application".
VW spent a lot of money developing the 2.0T/TFSI engines & boost control. Nothing against any of the other aftermarket manufacturers, but do you truly believe they could make engine driveability (boost control) better than VW?
GFB are a great company, make good stuff & know there technical stuff well. Would I recommend one of their valves to one of our customers as a great investment to spend cash on? No.
