Has anyone done this? I'm a little confused whether or not I will need to replace the CAN gateway...
RCD510 install in MK5 Jetta.
Re: RCD510 install in MK5 Jetta.
Yes you will need to either upgrade the canbus gateway or get the existing gateway upgraded by someone with the right tools. Transporter in Adelaide can do it not sure of someone local to you can do it.
Sent from my HTC One using Tapatalk 22011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
As Kamold says, most 05/06/07 cars need the sw update.Originally posted by jaredtomas View PostHas anyone done this? I'm a little confused whether or not I will need to replace the CAN gateway...
If you have the VCDS scan from your car you could check the cangateway sw against the list in this post http://www.vwwatercooled.com/forums/...all-75217.htmlPerformance Tunes from $850Wrecking RS OCTAVIA 2 Link
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
There is heaps of info about the topic on this forum and google. If you require the newer gateway it's not really worth it, I did the math when I was contemplating buying one and it was more cost effective to buy an ANS-510 (Do a search on this forum if you dont know what an ANS is) which had heaps more functionality then an rcd510 and doesn't require the gateway upgrade.MKV GTI
Interesting! I've had a look on eBay and the ANS510 is going for about $600, whereas the RCD510 is about $250..Originally posted by jessv3 View PostThere is heaps of info about the topic on this forum and google. If you require the newer gateway it's not really worth it, I did the math when I was contemplating buying one and it was more cost effective to buy an ANS-510 (Do a search on this forum if you dont know what an ANS is) which had heaps more functionality then an rcd510 and doesn't require the gateway upgrade.
I'm curious as to why the ANS wouldn't require the gateway upgrade? It's a much more beefier unit, as you said! So wouldn't that mean it'd drain more power?
The battery drain is due to the head unit not powering down after you switch the car off. The correct canbus gateway tells the head unit to power off after 30 mins.
The ans is not affected as it just turns off as soon as you pull the keys.
A dealer won't upgrade your canbus gateway unless you are really friendly with them. Vcds cannot upgrade the software on the canbus gateway either.
Transporter in Adelaide can do it but not sure of anyone else who can. Need the right technician tools.
You are looking at $1000 plus and lose the 6 stacker and get an HDD insteadOriginally posted by jmaxwell47 View PostWanting to upgrade my 05 golf FSi...it has the 6 disc stacker but would like to get gps added...anyone point me to someone in sydney that is affordable and can do the work?
Buy a Tomtom or a Garmin for $200 and go to the pub. You get a better 100% better GPS and a nice day out LOL2021 Kamiq LE 110 , Moon White, BV cameras F & B
