and don't forget the tread depth on your tyres can affect the accuracy of your speedo by up to 3kph
Check speed using Climate Control Read Out
It uses canbus signalOriginally posted by G-rig View PostI thought the climate control was essentially the GPS speed, or is that only if you got the RNS510?
I find the speedo on the dash a fair way out, 110 climate = 120 dash.
BazzlePrev 2008 R32 3 door DSG.
Now Lexus IS350 F Sport
The canbus speed is the GPS speed, my speedo is reading 8kmh high @ 100km/h (checked with canbus and additional GPS = same)
Originally posted by Fangy View PostI've been testing the speed over the last few days and I've noticed that when I'm doing low speeds of around 40-70kms it is out by 2-3kms but once I get up to the 90's - 100's it starts going out by 4-5kms.
Is this normal? -_-
I've also been using a GPS at the same time and the speed the climate control is telling me is pretty much on par with the GPS.
Golf "R" MY19 MK7.5, Passat B8 MY16 BiTdi, Audi SQ5, Vag-Com, OBDeleven,
Previous.. Golf MK5 TDi-GT Sport, DSG, Golf MK6 Tdi DSG,
Press the Econ button againOriginally posted by satz View PostI might have missed this in one of the posts, but how do you get back to 'normal' operation?
cheers
S_
2006 Golf GTI DSG | REVO Stg2+, REVO Stg 1 DSG, X-FORCE TBE, K&N Typhoon CAI, AT HPFP, Forge Twincooler, BSH Stg2+ Catch Can, ECS Mount Insert, DBA 4000 Slotted Rotors
John @ DNA Tuning Australia has just mentioned this possibility to me with regard to my B5 (99) Passat. Does this or something similar also work for Passats?
If it helps anyone I found these links for Passat B5:
PassatWorld
Audiworld
Holding the Fan Speed Down, Temperature Colder & ECON all at the same time worked for my B5 and the + / - temperature control buttons worked to scroll up and down through the codesLast edited by dav1129; 21-08-2012, 01:40 PM.2016 Amarok
That display can still be out. Best to check your speed with a seperate gps and adj to that.Originally posted by Thesnowburner View PostI recently found out that my speedo was out by 9kph, no wonder i have had no speeding fines. Now when i travel into VIC i just set cruise accordingly and Sa just set on 119. Maybe i would have been better not finding out.
