Check speed using Climate Control Read Out
  • Check speed using Climate Control Read Out
    Guys,
    I read on another website that it's possible to get the accurate SPEED reading of your golf via the Climate Control readout.
    Does anyone know how to do this???
    As we know the GOLF GTI 07 speedo is alittle off, i just wanted to check how off.
    Thanks,
    Larry
    MY2007 BM 3Door GTI, DSG, Parking Sensor, Carbon Tint Windows, GIAC X, Scratched Alloys on LHS - NOT done by me!
    Yup, Hold down "econ" button, and press the up vent (next to recirculate). Both temp displays will read 00 or 00 0, and you can release the buttons once they do.
    Twist the LEFT temp knob clockwise until it reads 19 0.
    Twist the FAN knob unti the left temp reads 19 1 (like 19.1).
    The right temp display is now a digital speedometer!
    For Tachometer turn FAN clockwise untill it reads 19 3.
    to cancel just hit the econ button again.
    LowVeeDub
    Sorry 19 0 is kmh 19 1 is mph
    It does heaps of measurements too i'll try and dig em up.
      This is what the rest of the numbers mean
      Main channel: 0 - System data
      0 Number program
      1 Left ERL
      2 Skillful ERL
      3 Point of job accensione/avvio
      4 I recirculate automatic rifle (motor)/I recirculate automatic rifle Bit
      5 Heating from active detention
      6 Air Quality (7 = fresh air)
      7 Deriving
      8 Acronym country
      9 Sensor zone head
      Main channel: 1 - UIF
      0 Inner temperature (°C)
      1 Surface Temperature (°C) (I think it means external)
      2 Temperature piastrine in platinum (°C)
      3 Corrector piastrine in platinum (°C)
      4 Uif-Sonnenint
      5 Corrector radiation (°C)
      6 dynamic corrector (°C)
      7 OrrettoreC I recirculate (°C)
      8 thermal corrector (°C)
      9 Compensation ignition (°C)
      Main channel: 2 - Sensor radiation SX
      0 Radiation not delayed (W/m2)
      1 Corrector radiation for regolator temperature (W/m2)
      2 Corrector radiation for impeller (W/m2)
      3 Value TO
      Main Channel: 3 - Sensor radiation DX
      3 Value TO
      Main Channel: 4 - External Temperature
      0 External temperature (°C)
      1 Temp. External line CAN (°C)
      2 Temperature inhaled air climate (°C)
      Main Channel: 5 - Theoretical temperature SX
      0 Theoretical Temp. air in escape SX (°C)
      1 Theoretical difference between temp. and temp. effective (°C)
      2 Value regulation the sx. (½% )
      3 Pi-Stell-Max (½%)
      4 Defrost SX
      Main channel: 6 - Found temperature SX
      0 Temp. Found SX (°C)
      1 Temp. Feet SX (°C)
      2 Temp. Facade SX (°C)
      Main channel: 7 - Theoretical temperature DX
      0 Theoretical Temp. air in escape DX (°C)
      1 Theoretical difference between temp. and temp. effective DX (°C)
      2 Values of regulation regolator (½% )
      3 Pi-Stell-Max (½% )
      4 Defrost
      Main channel: 8 - Found temperature DX
      0 Found Temp. air in escape DX (°C)
      1 Temp. Feet (°C)
      2 Temp. Facade (°C)
      Main channel:9 - Theoretical temperature evaporator
      0 Theoretical temperature evaporator (°C)
      1 Theoretical difference between temp. and temp. effective evaporator (°C)
      2 Values of regulation evaporator (5mA/Dig)
      3 Modality Regolator evaporator (you see under)
      Main channel: 10 - Effective temperature evaporator
      0 Effective temperature evaporator (°C)
      1 Pressure coolant climate (bar)
      2 Medium temperature coolant climate (°C)
      Main channel:11 - Climate control compressor
      0 Power theoretical electrical worker
      1 Power effective electrical worker
      2 Power electrical worker max
      3 Kompressor PWM (0... 200) (Dig)
      4 Power electrical worker offset compressor
      5 Values power electrical worker
      6 Code disinserito compressor (you see system)
      Main channel:12 - Climate control impeller
      0 Theoretical tension of the electric impeller (V)
      1 Manual regulation
      2 Code anomaly
      3 Reduction impeller (V)
      4 Impeller offset (0.1V)
      Main channel: 13 - Temperature bocchette air SX
      0 Formattato theoretical value (%)
      1 Real theoretical value temp. Bocchette sx.(Dig)
      2 Confirmation el. temp. Bocchette sx (Dig.)
      3 The maximum limit temp. Bocchette sx. (Dig)
      4 Limit min. temp. Bocchette sx. (Dig)
      Main channel: 14 - Temperature bocchette air DX
      1 Real theoretical value temp. Bocchette dx (Dig)
      2 Confirmation el. temp. Bocchette dx (Dig)
      3 The maximum limit temp. Bocchette dx (Dig)
      4 Limit min. temp. Bocchette dx. (Dig)
      Main channel: 15 - Piedi/centrale temperature bocchetta
      1 Real theoretical value temp. Bocchetta centers them (Dig)
      2 Confirmation el. temp. bocchetta centers them (Dig)
      3 The maximum limit temp. bocchetta centers them (Dig)
      4 Limit min. temp. bocchetta centers them (Dig)
      Main channel:16 - Defrost Shovel
      1 Theoretical value real Defrost shovel (Dig)
      2 Confirmation el. Defrost shovel (Dig)
      3 Limit maximum Defrost shovel (Dig)
      4 Limit min. Defrost shovel (Dig)
      Main channel: 17 - Shovel I recirculate inner
      1 Theoretical value real shovel I recirculate (Dig)
      2 Confirmation el. shovel I recirculate (Dig)
      3 Limit maximum shovel I recirculate (Dig)
      4 Limit min. shovel I recirculate (Dig)
      Main channel: 18 - Shovel cold air
      1 Theoretical value real Shovel cold air (Dig)
      2 Confirmation el. Shovel cold air (Dig)
      3 Limit maximum Shovel cold air (Dig)
      4 Limit min. Shovel cold air (Dig)
      Main channel: 19 - Data Motor
      0 Vehicle velocity (km/h)
      1 Vehicle velocity (Mph)
      2 Motor temperature (°C)
      3 Engine speed (RPM)
      4 Air con compressor speed (RPM)
      Main channel: 20 - Data sent by CAN
      0 Additional heating (upon request) (1 = on)
      1 Confirmation el. PTC (1 = on)
      2 Power el. effective PTC
      3 % air demanded from radiating climate (%)
      4 Relationship % of radiating peak air (%)
      5 No performance demanded to the disp. of heating (1=no performance heating)
      Main channel: 21 - Ripartitore of air Climate
      0 Defrost (%)
      1 Facade (%)
      2 Feet (%)
      3 Bocchetta areazione (%)
      4 I recirculate fresh air/cleaned up (+ bocchetta...) (%)
      5 Appraisal sensor (%)
      Main channel: 22 - Data timer
      0 Period of pause (min)
      1 Motor operating time (sec)
      2 Operating time with inserted key (Sec)
      Main channel: 23 - Special channel
      0 Sensor inner lighting system (Dig)
      1 Air quality sensor
      Main channel:24 - Version software
      0 Development state
      1 Software version
      2 Type SW
      3 Keep Frozen (0/1 = Values of refrigeration come maintained ad.eccezione.della Diagnosis )
      4 Version K Matrix
      5 EEP- Testflags
      6 It codifies Vag (2)
      Main channel: 25 - Test channels
      1 - 9
      Main channel: 26 - Parameters for surveys on crystals
      0 Delay (sec)
      1 Passo/udm (digit)
      2 The minimal limit (digit)
      3 Limit max. (digit)
      4 Passo/udm on HellaKit
      Main channel: 26 - Bocchetta direct areazione
      1 Theoretical value real Bocchetta direct areazione (Dig.)
      2 Confirmation el. Bocchetta direct areazione (Dig.)
      3 Limit max. Bocchetta direct areazione (Dig.)
      4 Limit min. Bocchetta direct areazione (Dig.)
      Main channel: 28 - Umidita
      0 Theoretical Umidita (%)
      1 Relative Umidita on temperature UIF (%)
      2 Temp. Crystals WSS (°C)
      3 Temperature condensation point (°C)
      4 Difference temperature of the melting point (°C)
      Main channel: 29 - Crude values umidita
      0 Temp. Crystals, corrected (°C)
      1 Temp. Crystals, not corrected (°C)
      2 Sensor umidita (%)
      3 Temperature sensor (°C)
      4 Temperature condensation point (test measure) (°C)
      5 Code anomaly
      Main channel: 30 - Values indicated to you umidita
      0 Value sensor termofilo (Dig.)
      1 Temperature rif. termofilo (Dig.)
      2 Periodic duration umidita (10 (to the power of -4) sec)
      3 Temp. Reference umidita (Dig.)
      4 Umidita Rel. on the sensor (%)
      5 Temperature sensor umidita (°C)
      6 Temperature crystals (not corrected) (°C)
        Originally posted by Mister_duck View Post
        This is what the rest of the numbers mean...........
        Yeah, but does it make coffee?!
        Great post.
        SS
        2018 Golf GTI, Manual - gone.
        2017 Golf 110tsi Trendline, manual (gone - gladly)
        2007 Golf GTI, Manual, (gone - sadly)
        1978 Golf GLS; 1972 Superbug, (memories)
          Wow~ THANKS!!!
          Thanks heaps for the info!
            This is way too cool. Thanks Mister_Duck.
            MY07 TDi DSG beige leather bi-xenons & 3M car bra
              What I want to know is how long someone sent finding this stuff out...!!!
                Where is the econ button? I cannot find it in my 09 Golf pacific.
                Lapiz Blue GOLF R MY16
                  Use the AC button instead in MY09 models.
                  MY09 MKV GOLF GTI | RS | 5D | MT
                    awesome just took my gti for spin and amazed with all the info most of it goes over the top of my head but very interested in code 19!!! it will keep me busy while sitting on the gateway every morning
                    07 GTI SILVER DSG (SMART PEOPLE HAVE DSG)
                      On the freeway i set the cruise to 110 on the speedo, real spead is about 102-103. Perfect, no ticket.
                      Ive found that the speedo is about 9% out.
                        Updated information on the codes is available from here
                        website: www.my-gti.com
                          select dual air-con zones first
                          Please note this feature requires that you have selected dual zone air-con, too. Correction - this is not necessary.
                          Very cool (no joke intended).
                          Interestingly, I've also found the difference is usually a little under 10%. Are we saying VW deliberately 'enhance' the normal speedo readings, but the 'digital' speedo is more accurate because it is the 'raw' data?
                          TG
                          (formerly TSI GUY)
                          First car: 1972 White Super Bug S
                          First Golf: MY08 Candy White Golf GT Sport TSI DSG
                          Now: MY13 Candy White Golf VI 2.0 TDI DSG (yes, I've come over to 'the dark side'...)
                            Another way to check your speed more accurately is to use the MFD.
                            From GTI.com . .
                            . . . go to the speed alert screen, press ok until three dashes show and clock ok, the warning speed is your . . . [actual] speed. This is a static display so use cruise control on a flat level surface.
                              Most people find the climatronic speed reading agrees pretty closely with a GPS speed, whereas the speedo always reads faster (by varying amounts, which can be different at different speeds) depending on the individual car).
                              And yes, the most popular theory is that VW deliebrately do it so they can't be sued by people indavertantly speeding and also to comply with the ADRs etc which also say someting about speedos not reading "slow" (reading faster than the true speed is OK apparently)
