Mk5 FAQ and DIY Thread
This is a sticky topic.
    Here is another one...
    How to change wiper blades refill?
    I believe that dealers are charging too much for rears and front. So if anyone knows a good link on how to's please post?
    If not I am going to try to figure it out one day and post pictures
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
      Is this what you are looking for?
        Spot on FJ Steve.....
        Thanks
          Quick question: Did the MkV GTI come with a sunroof as standard?
            No, it was optional.
            Usually retailed for $1850.
            Very happy with mine.
            The aftermarket versions were $2000+ and looked added on.
            2007 Golf GT | DSG | TR | roof | iPod rubbish | R line fog grilles | R satin mirror caps | R pedals | R console trim | colour coded GTI valences | R32 Ormanyts
              Oh cool, thanks. I keep discovering extras on my car that I didn't even realise were extras... Yeah very happy with mine also.
                this is the link I was looking for adjusting the head lights
                  Originally posted by Logzy View Post
                  There was a really good one somewhere with photos etc.
                  I just cant remember where.
                  Anyone??
                    Dayco engine belts and thermostat part numbers.
                    Golf
                    Jul 2004 - , 3.2L, V6, 24V, DOHC, MPFI, Engine Code: BUB
                    Part number Application
                    6PK1245 Belt Alt & A/C
                    DT62A Thermostat
                    DTG31 Gasket (Rubber Type)
                    Aug 2004 - Feb 2009, 1.6L, 8V, SOHC, MPFI, Engine Code: BGU
                    6PK1050 Belt Alt & A/C
                    94730 Belt Cam
                    KTB253E Kit Cam (Euro)
                    DT14G Thermostat
                    Aug 2004 - Feb 2009, 1.9L, 8V, SOHC, DTFI, Turbo, Diesel, Engine Code: BKC
                    94885 Belt Cam (PTFE)
                    KTB296E Timing belt kit
                    DT36G Thermostat
                    Aug 2004 - Feb 2009, 2.0L, 16V, DOHC, MPFI, Engine Code: BLX
                    94979 Belt Cam (PTFE)
                    Aug 2004 - , 2.0L, 16V, DOHC, DTFI, Turbo, Diesel, Engine Code: BKD
                    94970 Belt Cam (PTFE) 30mm wide belt
                    KTB441E Kit Cam (Euro)
                    May 2005 - , 2.0L, 16V, DOHC, TMPFI, Turbo, Engine Code: AXX
                      Stumbled across a DIY way to hook up a towbar to CAN BUS cars, such as the VW's for about $50 plus towbar. Wish I'd seen this at purchase time, would have saved me about a grand!
                      http://www.autospeed.com.au/cms/A_111415/article.html
                        Originally posted by mikinoz View Post
                        Please feel free to suggest threads for this sticky!
                        Maybe a sticky with a list of changes for each MY of the Mk 5 GTI?
                        T Go
                        MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
                        • #27
                          Remove the tailgate trim
                          Can anyone help me?
                          I was teaching my daughter to drive and we had a slight mishap reversing into an overhanging tree.
                          There is a minor dint in the tailgate just to the left of the right hand reverse light cluster. I reckon if I could get the tailgate trim off I could push it out but I don't know how to get the plastic trim off.
                          Any clues?
                          Thanks,
                          H
                          MY08 Golf 2.0 FSI Pacific
                          • #28
                            I found this one...
                            Rear Wiper Blade Replacement - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
                            • #29
                              AC Evaporator Drain - access on RHD Golfs.
                              This might be useful for anyone who wants to check whether their AC evaporator drain is blocked. Perhaps due to noticing water on the carpet, or mouldy smell when running the AC. Probably applies to all Golf V models, and also Jettas of the same vintage.
                              Anyway, here's my post from another website, including photos. I can't work out how to put up pix here!
                              please help: where's the AC drain on the Golf V GTI? - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
                              It's a rather more complicated procedure on our RHD cars, compared to left, but still do-able. Looks like you won't be able to easily access the evaporator drain from outside the car, so this seems to be the only way to get to it.
                              Any questions, please feel free to ask!
                              cheers
                              Satz
                              • #30
                                Hi all,
                                just changed the look of my red grille stripe on my mkv...
                                link to diy here: DIY - MKV Red Grille Stripe Removal and Colour Change
