Cheap and relatively easy to do, but a unique result and it's something you can do yourself, I like it
Mk5 FAQ and DIY Thread
This is a sticky topic.
Hi All,
I would like to find out if anyone knows that the following Auto Diagnostic Fault Scanner CAN BUS Code Reader work on my 2008 Jetta FSI 2.0?
U281 CAR Auto Diagnostic Fault Scanner CAN BUS Code Reader FOR Audi VW Jeta Golf | eBay
Regards,
Fuel injectors replacement
Diy suggestions
Sent from my iPhone using Tapatalk2006 vw golf gti APR Stage 2+ ,APR full exhaust, VWRacing cold air intake,APR fuel pump
APR intake flap delete, tarmac intercooler, wheel spacers , R8 coil kits, new south performance gauges , bsc PVC revamp and heat shield, Koni sport shocks and springs set
Pcd on all mk5's is 5x112, offset is dependant on the wheels you are running stock 16x6.5s are about et48 if I remember correctly, please correct me if I'm wrong.Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
Welcome to the MkV Frequently Asked Questions (FAQ) and Do It Yourself (DIY)Thread!This thread has step-by-step process write-ups, links to ...
