Mk5 Golf/Jetta Problem Registry
This is a sticky topic.
  • Had abit of a strange oddity occur last night on the trek home from work. The Passenger side window had a mind of its own and, continued in closing and opening, and engaging the window switch had no effect. Seems to have disappeared this morning though, must be a gremlin at work
    • Originally posted by acdcfan View Post
      As it turned out it was ECU unit with loose connection that was working on and off.... giving turbo wrong indication of what to do. That was one of the reasons why my car wanted to do a wheelie when launching from the first gear
      Got that fixed and got the ECU software upgrade as well. In the process of find out the fault for the turbo, VW dealership has diagnosed that I have an indication of possible fly wheel failure. Upon further inspection, new fly wheel is getting ordered to be replace.
      Funny thing is that I didn't know that VW have dual mass fly wheel and they they do come out of alignment which was why I was hearing funny noises after clod start, when pressing on the clutch noises disappear.
      Turbo is good now....
      Good to hear.
      At just 20,000km I foud oil drop at the bottom of the steering rack.
      I wonder if anybody else noticed it on theirs.
      It is sealed unit and I don't think it can be topped up.
      [ATTACH]4685[/ATTACH]
      [ATTACH]4687[/ATTACH]
      Yeah last service at Solitaire they found an oil leak near the gearbox/sump region.
      Car has done approximately 28-29K.
      - Ben
      2008 Jetta 2.0L FSI
      • Heya guys,
        so my second GT TDI has a bit of an oddity about it. Occasionally there is a real flatspot up to about 2200 rpm, like the turbo is not making boost. Once above that rev range, it's fine - pulls very hard from 2500 up, every time.
        It's only intermittent.
        Boost leak maybe?
        "One art please!" --->http://benno.redbubble.com
        • Rear clunk
          My new GTI (3000kms) has a persistent rattle that sounds like it's coming from the rear left corner of the car. Noticable over road imperfections and also at other times. No vibration etc, nothing loose in cabin / boot.
          Is this the tail light clunk, and if so (or if not), will the dealer investigate this FOC or will they sting me a fortune? I'd like it fixed as the car is awesome otherwise but this is driving me nuts.
          Gone: 2009 MkV GTI DSG United Grey; 2005 MkV Comfortline
          Current Rides: 2020 Mk7.5 GTI Performance ; 2013 MY14 V6 Touareg 180TDI
          • I too have a rattle, which is starting to bug me! It appears to be somewhere in or under the drivers seat. When I break, I can hear it rattle/clunk. Almost as if a coin has been dropped down there. Pretty annoying!
            Genuine VW Parts Importer | Navigation | Bluetooth |
            Repairs | Lighting | Coding | Programming |Cameras
            • Coil pack light came up a couple times last night!!!! uh oh
              MY 2008 VW Golf GT-Sport TDi Weitec Hicon GT Coilovers, Alpine System
              • Originally posted by adrian112 View Post
                You're not driving it hard enough!
                When my PDF got a bit clogged, they regenerated it and essentially told me to drive it harder.
                Has it been idling at 1000rpm at all recently?
                • didnt think the coil packs had anything to do with the DPF? maybe im just noob hehe....
                  • Originally posted by docjames View Post
                    My R32 as well. Dealer check all mounts, bolts etc. Ive also checked all I can see
                    Only heard occaisonally when going over small road imperfections etc.
                    Bazzle
                    Prev 2008 R32 3 door DSG.
                    Prev 2010 S3 Sportback Stronic.
                    Now Lexus IS350 F Sport
                    • Check back through this thread.... it is most likely the cord and bob that holds the parcel tray/cover in the back. When the hatch is closed the cord runs through the cover and the weight bob is what bounces around as it just hangs down and swings.
                      SPoddy
                      2020 Tiguan 162TSI R-Line
                      • It's not that - ive had that weight bob noise in the 2.0FSI and its a completely different sound. This is more prominent when it's a jiggly rough road, rather than over say speed humps etc.
                        • Originally posted by Spoddy View Post
                          Already removed.
                          • TSI s/charger wiring issue
                            Originally posted by tsi guy View Post
                            ... I've found the engine is almost backfiring first thing when I head up a hill from my home unless I really 'feather' the throttle (and don't exceed about 30 km/h). Twice I've had the engine warning light flicker about 5 times and then stay off (I understand - from RTM - that this is an 'exhaust system' warning light; I'll be taking the car in this week to see if it is merely cold weather running, though I don't recall this happening last winter, which was about the same temperature)...
                            Just been informed by the dealer that the problem was not DSG or dodgy fuel etc but some pins sheared off the manifold! I'll post further details when I get a fuller explanation. Likely caused by engine movement, apparently, so a warranty job (luckily for me).
                            Perhaps worryingly, he said he identified the exact cause of the problem within seconds of driving the car (which suggests it may be a common problem).
                            I've been told it related to the supercharger pressure control thingee, hence the wide swings in boost pressure betwen 1600 and 1900 RPM. The electrical harness wasn't long enough to allow for normal engine movement, so the harness was torn off. Not a problem for TDI's, clearly...
                            All fixed now, with a longer electrical harness which should avoid the problem re-occuring. Looking forward to driving it again tonight (and a return to that smooth power delivery...).
                            Thought I'd add this to the register, for future reference.
                            (formerly TSI GUY)
                            First car: 1972 White Super Bug S
                            First Golf: MY08 Candy White Golf GT Sport TSI DSG
                            Now: MY13 Candy White Golf VI 2.0 TDI DSG (yes, I've come over to 'the dark side'...)
                              Maybe something fallen into the spare wheel well?
                              SPoddy
                              • Weird thing happened to me on friday.
                                i was sitting in my new gti only done 1900km on it, had the radio on as i was waiting for my gf, the car decided to switch itself off while the key was still in it. and everything went blank so i took the key out and restarted the car, and the data in MFD had all gone, it was like the processing unit has restarted itself is that normal? anyone else had that problem??
                                apart from that i love the car and i have to say best car drive around.
                                MKV Golf GTI Black Magic
