Cruise Control
  • #16
    mine did the same thing 2 weeks ago... got it replaced under warranty. They supplied a new stalk.
    • #17
      I also leave mine on all the time and engage when desired.
      Check that it may be your brake light switch. The 'rents had this problem on their car and it turned out to be just that (fixed under warranty). Good luck mate
      • #18
        mine has been intermittently working (or not) since i bought the car.
        the switch itself seems to work fine (the green symbol on the dash always turns on and off with the switch)
        but sometimes the set / resume button refuses to engage the cruise system.
        i don't know what im looking at (cost wise) as it's out of warranty too.....
        i thought possibly a faulty brake light switch that's preventing the cruise engaging properly.
        will a faulty brake light switch throw a code ?
        Jason.
        05 Golf 1.9 TDI comfortline DSG
        • #19
          @85turbo, yeh it's been the same for me... very temperamental, sometimes it works and sometimes it doesnt...
          I've been putting it off for a while but because I'm doing more trips up the coast now, having it for freeways will be handy... dropping it off at chatswood classic cars tomorrow afternoon so hopefully will get the problem resolved :/
          MY06 GTI: 5 Dr, Reflex Silver, Sunroof, Pioneer AVIC-HD3, OEM Sharan Antenna, GIAC (Stage 1)
          MY08 .:R36 : 5 Dr Wagon, Biscay Blue, Sunroof, RNS 510
          • #20
            Oh, you don't have to wait until the problem appears again before taking it to a dealer... The actual c/c unit logs a fault code, so the dealer's will know it did fail and replace the unit (if under warranty)
            • #21
              dropped off the car yesterday and just got a call fm the CCC service team... same as what others have reported - faulty stalk... $300 for the replacement...
              • #22
                As many others have said, ours failed due to the stalk & it was probably my fault in that i used to flick the switch to disengage the cruise. It was replaced under warranty & now stays in the on position & we've had no problems since. Oh and I don't flick it off anymore
                Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
                2012 BMW X3 MSport 2.0D
                • #23
                  I read somewhere in UK, the new stalks are made by another supplier. You can tell if you have a new stalk if there is more writing on the unit - including "cancel" and bigger headlight icons showing high beam, low beam, flash, and more Cruise Control labelling. (ie. Set, Reset, +, and -).
                  So if you have the old stalk, and it stuffs up even once, make sure you get it changed over - otherwise it could cost you money after your waranty expires. - Especially if you have the APR Ecu upgrade which uses the stalk to change settings.
                  • #24
                    interesting... will keep and eye out when I pick up the car this afternoon
                    • #25
                      My car is booked into get the cruise control looked at next wednesday at hornsby.
                      • #26
                        When i started this thread, i just called up and told them the problem, brought it in, and the stalk was changed under warrenty, no questions asked....
                        BLACK 2.0 FSI Jetta -
                        Transforms - http://www.youtube.com/watch?v=SgjFFxjkZlQ
                        • #27
                          Originally posted by anthony_VWJET View Post
                          YAY one more thing to look at before the Warrenty dies out!
                          Anything else i should get looked at before the warrenty goes?
                          i had issue with my brakes. it make squeaky noise.
                          156 --> MKV GTi 08
                          • #28
                            turns out, my problem is related to a faulty brake light switch.
                            ill be replacing the switch this weekend.
                            total cost a whopping $22.80.
                            i figured out what was going on when the cruise would not engage, and i toggled the brake pedal a little, then the cruise would engage.
                            so ill replace the switch, and that should fix my issue.
                            ill report my results once it's done.
                            Jason.
                            • #29
                              Don't know what the fuss is all about. My cruise control always works properly. It comprises of right foot and quick scan of speedo every 10 seconds or so!
                              • #30
                                Learnt something about my cruise just the other day (which works fine, btw). I finally realised that the on/off switch also doubles as a cancel switch (pressing slightly away from on). That'll teach me for not R'ingTFM. Prior to that I was touching the brake pedal or turning it off completely.
                                p.s. found this out when I was having a look at my dad's Octavia RS, which actually shows the word "cancel" near the switch. Certainly no "cancel" written on the MKV's combination switch.
