Has anyone had the same problem with Cruise control not turning on?
Cruise Control
Originally posted by anthony_VWJET View PostHas anyone had the same problem with Cruise control not turning on?
George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
The cruise control switch is known to give problems. I had mine replaced under warrantee. I leave mine switched off most of the time these days and only turn it on when I am driving longer distancesPar 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
Originally posted by gtimk5 View PostThe cruise control switch is known to give problems. I had mine replaced under warrantee. I leave mine switched off most of the time these days and only turn it on when I am driving longer distances
RussRuss
Originally posted by faisan View Post+1
Mine is working fine alsoLast edited by anthony_VWJET; 17-02-2009, 01:17 PM.
Originally posted by anthony_VWJET View PostI was driving down to Jervis Bay, and everytime i wanted to switch it on, it wouldnt. The switch would be on but no cruise control symbol. At every light id be restarting the car and trying it, and it still didnt work. Though when i stopped by somewhere and turned the car off for say 5-10min, i'd try turn it back on and it'd work.... is it me, or is it the CC?
Originally posted by VW Convert View PostSounds like an issue for the dealer.
George
Anything else i should get looked at before the warrenty goes?
Originally posted by anthony_VWJET View PostYAY one more thing to look at before the Warrenty dies out!
or 3 months after it runs out your aircon could "self-destruct" itself......Last edited by gerhard; 17-02-2009, 05:03 PM. Reason: Net Nanny removed an everyday word for "self-destruct"sigpic
There has been a known problem with the CC stalk, symptoms are intermittent failure to engage, and also dropping out when engaged.
You might want to get them to check for any codes relating to a faulty brake light, as sometimes it can cause problems for the CC (and lots of other symptoms too).
If you have a TDI engine I'd get the turbo checked out too.
If you have a 2.0 TFSI engine get the cam follower for the high pressure fuel pump checked for wear.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
bummer, it seems i've picked up the same problem...
have a 05 mk5 Golf GTI and now have the CC issues :-/ and worse still it's run out of warranty as well :'(
has anyone taken this issue to the dealership? was it a major fix or a minor problem?
thanks!MY06 GTI: 5 Dr, Reflex Silver, Sunroof, Pioneer AVIC-HD3, OEM Sharan Antenna, GIAC (Stage 1)
MY08 .:R36 : 5 Dr Wagon, Biscay Blue, Sunroof, RNS 510
i have the same prob from the sound of it.. mine is booked in to the dealer in the next week or so as i need my elec windows fixed also.
my cc will sometimes not turn on at all... have to stop the car and restart then it works. its an intermittent thing so will pressure them to change the switch.
my elec windows i noticed the rear passenger side will not operate on auto. i have to hold the switch (drivers control) the whole time to get the window to operate. I think it is to do with the main lockout on the drivers door coz this doesnt seem to work now either. can still operate the rear windows with the switch on.1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
I just called the dealership in my local area and have booked it in for a look this Friday morning...
I've read several articles about the actual stalk problem and it's a simple replacement (maybe faulty switch i guess), so fingers crossed it's only a minor issue...MY06 GTI: 5 Dr, Reflex Silver, Sunroof, Pioneer AVIC-HD3, OEM Sharan Antenna, GIAC (Stage 1)
