Hi All
I have recently started to experience an issue with my 2008 TDI MK5 golf DSG. Out of no where, when I try and start the car - I turn the ignition key to start the car and I see PRNDS all lighting up flashing. When I then try and start the car - it turns over but won't start. If I cycle through ignition off / on enough times then it will start eventually. Once started, the car drives just fine. No noises from the gearbox, no odd shifts - nothing which would indicate an issue. Also the shifter is not stuck in park nor has this issue happening while driving. Only when the car is parked for an extended period of time.
I have been googling and noticed that some people have issues with a sensor in gear shifter or even faulty ground connections.
Has anyone had this issue and solved it without replacing the DSG or mechatronics unit? I actually was planning on selling the car soon and typical VW has to start to have a major problem.
Many thanks in return!
