I had a little moment today when the transmission clunked while coasting down hill at 60km/h in 6th gear.
Only lasted a second, felt like it slipped to neutral, I feather touched the accelerator and things were fine again.
The Mrs complained of something similar last week but could not give any real details.
I have been worried for a while as there is a suspension sort of rattle now and then on rough roads. Gear changes are not always as smooth as I would like. I have been planning on getting under to check the trans mounts, but cannot do that till I move back home in December. Both top engine mounts were done a while back as they were toast.
Perhaps a wiring harness is broken somewhere ??
Here is a scan.
(EGR is a known long term thing that I have been ignoring )
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 EK HW: Hardware No
Component: MED9.5.10 G00 9607
Revision: 69H03--- Serial number: VWZ7Z0F3632610
Coding: 0000075
Shop #: WSC 22040 959 86313
VCID: 76E47EF701D49A8E77-8022
2 Faults Found:
005120 - EGR Valve (N1
P1400 - 002 - Electrical Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 29
Reset counter: 255
Mileage: 182549 km
Time Indication: 0
Date: 2000.00.00
Time: 07:35:28
Freeze Frame:
RPM: 1920 /min
Load: 90.2 %
Speed: 60.0 km/h
Temperature: 51.0°C
049409 - No Communication with Transmission Control Module
U0101 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 183475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:48
Freeze Frame:
RPM: 720 /min
Load: 44.3 %
Speed: 2.0 km/h
Temperature: 78.0°C
Readiness: 0000 0001
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No: 09G 927 750 FB
Component: AQ 250 6F 0709
Coding: 0000072
Shop #: WSC 00066 000 00000
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01316 - ABS Control Module
01312 - Powertrain Data Bus
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001062130925
Coding: 3F3F0740071003
VCID: 2A5C9A8785EC8E6E23-807E
1 Fault Found:
01315 - Transmission Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 183475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:49
Here is a scan.
Coding: 0000075
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 29
Reset counter: 255
Mileage: 182549 km
Time Indication: 0
Date: 2000.00.00
Time: 07:35:28
Freeze Frame:
RPM: 1920 /min
Load: 90.2 %
Speed: 60.0 km/h
Temperature: 51.0°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 183475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:48
Freeze Frame:
RPM: 720 /min
Load: 44.3 %
Speed: 2.0 km/h
Temperature: 78.0°C
Coding: 0000072
3 Faults Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 183475 km
Time Indication: 0
Date: 2000.00.00
Time: 16:49:49
