hi I'm having a problem with my transmission,
This input shaft bearing behind the front passenger wheel, has pretty much exploded and needs replacing.
I'm wondering if I buy a kit like this:
https://www.ebay.com.au/itm/VW-GOLF-V-2-0-TDI-02Q-6-SPEED-LATE-GEARBOX-TOP-BEARING-OIL-SEAL-REPAIR-KIT/173297980650?hash=item28595d54ea:g:UZ0AAOSwf1xcQdp I
If I can do the job without removing the engine and transmission?
Also since this bearing has gone, does it indicate I will need to check/change other bearings as well?
Thanks in advance
Thanks in advance
