My wife's 2.0 litre FSI non-turbo Golf V suddenly has a very bad idle which is giving an error message of 008825-leak in air intake system P2279-008-MIL ON, plus 000768-random/multiple cylinder misfire detected and 000769-cylinder 1 misfire.
I've done a search for these error codes and looks like it often points to a leaking PCV valve but if I remove the oil cap it stumbles and almost cuts out so probably not the PCV (?). Any better way to test the PCV valve?
I attached a DIY smoke machine I have to a vacuum input on the throttle body and there are wisps of smoke coming from deep down in the areas marked on the attached pic, underneath intake manifold runner Nr 1 but I can't pinpont the exact souce as there's too much in the way. Is there anything in this area that commonly springs a leak? Where does the long rubber vacuum hose in the middle of the pic attach to at the lower end, and is this a common place for a leak to occur? (We replaced the little plastic hose from the PCV valve a few months ago and looks like its still ok.)
This is the only area which is showing smoke with the smoke tester. Any ideas?
