After having removed and reinstalled my wiper assembly the wipers will no longer go into service position. When I initially removed the wiper arms they were in the service position as well as when I reinstalled them. However whenever I try and do it now (ignition on, ignition off, hold down wiper stalk) they do nothing? Did I mess something up with the motor when I removed it?
Wipers won't go into 'service position' anymore.
 The wipers work fine. I pulled the whole wiper mechanism out but I didn't detach the motor from the arms.
 Reinstalled everything the way I pulled it out.Last edited by sebas_thefish; 08-04-2019, 11:20 AM.
 I don’t suppose you’ve done a VCDS scan by any chance?
 Did you disconnect the wiring when you pulled it out.
 Ignition on then off and tap stalk down should be the procedure but you obviously know that as you’ve done it before.
 I was thinking maybe bonnet switch faultbut that would stop the wipers altogether.
 That’s very odd behavior I’ve been having a look through all the docs I can get my hands on can’t see anything that would indicate a problem. I don’t have access to my daughters golf at the moment and the wife would shoot me if I pulled her Amarok apart to see I noticed though in one doc it specifies that the wipers should be in the parked position before disconnecting them and the battery should be disconnected first. Maybe disconnecting and reconnecting may reset the integral controller?? I noticed though in one doc it specifies that the wipers should be in the parked position before disconnecting them and the battery should be disconnected first. Maybe disconnecting and reconnecting may reset the integral controller??
 My wipers were up in the service position when when I removed the arms so I'm thinking that has messsed it up. Battery disconnect is the only thing I haven't tried yet.Originally posted by saabman View PostThat’s very odd behavior I’ve been having a look through all the docs I can get my hands on can’t see anything that would indicate a problem. I don’t have access to my daughters golf at the moment and the wife would shoot me if I pulled her Amarok apart to see [emoji38] I noticed though in one doc it specifies that the wipers should be in the parked position before disconnecting them and the battery should be disconnected first. Maybe disconnecting and reconnecting may reset the integral controller??
