I dont have access to the idle plots but the 2000 rpm plots are fine
The 2000 rpm plots look good the constant 7% partial throttle trim while the idle is only around .5% is interesting it seems tio indicate leaning out as the throttle opens maybe a that from what i've read points to MAF issues but I believe we only have a MAP sensor mine was mounted rather low on the manifold and full of oil. I cleaned mine out with brake/parts cleaner. only one torx screw holds it in but there is not much room between it and the radiator, just fiddly not impossible. I seem to recall pulling something else off to make it a bit easier to get to. Cleaning it didnt help the engine running at all. I didnt have any before and after logs -haveing said that maybe I do, Ill have to dig a bit deeper.
I bought a cheap leak down tester of ebay - it is very dodgey and doenst really work properly. basically it hooks up to an air compressor and pumps air into through the sparkplug hole and gives you a measurement of air leaking out of the cylinder. The advantage over a compression test is you can pinpoint where you are loosing compression. If you have a way to pump air in to your cylinders you can do it as well. The idea is you pump air in and listen to the oil filler (remove the cap first) intake manifold and exhaust. if you can hear air escaping through the intake it means you have an intake valve not closing through the oil filler you have leaky rings (a bit going past the rings is normal)
The kit just gives some guages and regulator so you can determine the amount of leakage so you can compare cylinders. the cheap one dosent work properly so that bit doesnt work but its great for getting regulated air into the cylinder and have a listen. I didnt even give it a thought to put it on nats car when I had it here
i used to use it a fair bit when i had a couple of air cooled vws on the road, thats a whole another story...
I did some scans on the wifes Amarok and been a diesel i couldnt see anything worth logging. I ll have another go at TFSi at work tomorrow.
