Hmm definatly looks like a problem with #1 in some fashion. Might be time for a physical inspection! It only takes a few minutes to pull the manifold off but half a day to put those damn clips back on!
I found all my valves were pretty evenly coated in crud but not badly ( in my opinion anyway)
I’ve been working on trying to find out what the parameters are for the cold start high idle. I have been looking for a copy of the med9.5.1 funksionrahmen (that’s not spelt right) but with no luck - the best I’ve been able to find is for the 9.1 Im going to take stab in the dark and hope they are similar enough to get an idea as to what’s happening. Ive started translating the index using google translate. Once I’ve got the index finished I’ll post it up. I hope to then have an idea which sections are possibly relevant, I’ll then translate those which will be slow going. I might start another thread with the translation work.
I’ve also been contemplating the 500ohm reading for the heater resistance, that seems way to high - that equates to less than 300mW that’s the power of 2 LED dash lights - like nothing. You can generate more heat rubbing your hands together.
