Originally posted by MEL744
View Post
i wish it was possible to log everything while starting rather than been limited to about a dozen values.
Its pretty easy to check the gears in the egr you can pull the cover off with the egr valve still in the car, its only about 6 screws.
its also reasonable easy to remove the whole valve as well if you want to clean it out.
have you done a full vcds auto scan ??
if your engine usues the more common purge valve i have a good (new ) that doesnt fit my daughters car i ordered incorectly..
