Dsg misbehaving... Help!
  • Dsg misbehaving... Help!
    Was driving home from work today and the dsg in my gti decided it would take a bit of a nap.
    After 10 mins of driving and from a take off it just revved like it was in neutral. Looked at the dash and PRNDS were flashing... Turned car on / off a few times but nothing. Couldn't even push the thing as it felt like it was stuck in gear.
    Codes below appeared:
    P0784 (power train)4-5 shift
    P0829 (power train)
    P2711 (power train) unexpected mechanical gear disengagement.
    After a few minutes of the car being off and people beeping as they had to drive around all seemed good and car was driveable.
    Some quick googling shows many possibilities.... Has anybody experienced similar issues?
    150k on the odo and its had its 2 dsg services on time (60k intervals).
    Thoughts anybody?
    Sent from my SM-G950F using Tapatalk
    These are the generic SAE codes.
    You need to use something like VCDS to get the manufacturer specific info out of the faults to make a proper diagnosis.
      Thanks mate. I retrieved these while at the side of the road...
      I'll pull out the laptop with vcds and see what it says... Probably shouldn't of cleared the codes though!
        I've had trouble free driving since clearing the fault codes 5 months ago but on the way home from work they appeared again...
        A short loud screech noise (similar sounding to air being released?) was followed by a flashing check engine light and no gear engagement.
        Can anybody please help me decipher the fault codes below ?
        4 Faults Found:
        18115 - Interference in Mechatronic Module
        P1707 - 011 - - Intermittent - MIL ON
        Freeze Frame:
        Fault Status: 10101011
        Fault Priority: 0
        Fault Frequency: 255
        Reset counter: 40
        Mileage: 157041 km
        Time Indication: 0
        21015 - Unknown Error Code
        Unknown - 000 - - Intermittent
        Freeze Frame:
        Fault Priority: 0
        Reset counter: 40
        Mileage: 157041 km
        Time Indication: 0
        P1707 - 008 - - Intermittent
        Freeze Frame:
        Fault Status: 00101000
        Fault Priority: 0
        Reset counter: 40
        Mileage: 157041 km
        Time Indication: 0
        P1707 - 003 - - Intermittent
        Freeze Frame:
        Fault Priority: 0
        Reset counter: 40
        Mileage: 157041 km
        Time Indication: 0
          Reset your mechatronics unit.
