traction control light wont turn off
  • traction control light wont turn off
    Just to clarify, i drive an 8L S3 so maybe you mk4 gurus could shed some light on my issue...
    the other night I was driving the car home and about halfway into the trip the traction control light decided to turn on; I did not manually press the ESP button at all. Now every time I drive the car, the TC light comes on as soon as I start the car without me pressing the ESP button.
    I changed the MAF sensor with a brand new one (as thats what other forums have said to do) and that did not fix my problem. I don't have direct access to a VCDS but could it be that my haldex has finally let go?
    I plan on getting it scanned asap but yeah, just trying to figure out possibilities.
    .:R32
    8L S3
    Mk3 VR6 - SOLD
    Flickr
    Maf has nothing to with the esp.
    Maybe you have a bad wheel speed/ABS sensor, or the sensor disc has gunked up.
    I had a loose speed sensor once and it made abs kick in all the time, no traction control on that car however.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
      true true, I'll give them a clean and see if that changes anything.
      ABS light isn't on so I think it could do with a scan.
      .:R32
      8L S3
      Mk3 VR6 - SOLD
      Flickr
        Had many an S3 with a bad maf and esp light on at same time,new maf and no esp light.Strange but true.
        Widebody Cayman S Turbo, 83 ur Quattro
        2000 996 C4 cab,12 Scirocco R OEM+ STG2+
        72 914 (3.2S boxster pwr), 92 G60 Corrado
        76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
          Best find someone with VCDS next and see what the cars says is wrong. ESP and TCS won't work if the ECU can't see what is happening with the engine, ie what the airflow through it is.
          Other failures can cause the same lights to come on though, ABS failures, no wheel speed at one corner or the YAW sensor.
            Cheers Gavin. Yeah a scan is what I'm going to get done - no more guess work and it'll give a straight answer. Thanks for the input fellas
            .:R32
            8L S3
            Mk3 VR6 - SOLD
            Flickr
              wheel bolts tight?
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
                wheel bolts tight?
                hahahah, that was the first thing I checked lmao
                .:R32
                8L S3
                Mk3 VR6 - SOLD
                Flickr
                  Which car fid you do the brake upgrade on?
                  Bora gone
                  Vento VR6
                  MKIV GSW TDI
                  7P Touareg TDI
                    Put the 4pots on the S3; R32 gets no love
                    .:R32
                    8L S3
                    Mk3 VR6 - SOLD
                    Flickr
                      ok, so I managed to get the car scanned over the weekend and I was greeted by the lovely "no fault codes found"...
                      im stumped lol. I had my CV's replaced just the other week, before the TC light came on, so my guess is either a wheel speed sensor or something ABS related.
                      .:R32
                      8L S3
                      Mk3 VR6 - SOLD
                      Flickr
                        If there's a light on, there must be a fault. Did you scan all the controller, or just the engine ECU?
                          Thats why I'm stumped, because I know there has to be something wrong...
                          Tbh, I'm pretty sure it was just the ECU that was scanned
                          .:R32
                          8L S3
                          Mk3 VR6 - SOLD
                          Flickr
                            what system was used to scan it ?
                              a legit rosstech cable
                              .:R32
                              8L S3
                              Mk3 VR6 - SOLD
                              Flickr
