Id rather do without it if possible.
Do you really need the special tool to remove the spark plugs?
Re: Do you really need the special tool to remove the spark plugs?
What cable, the plug lead/coil lead? Should just pull out, they will be firm.
You don't need the plug socket unless the plugs are heavily recessed, and if they are you can use a telescopic magnet toll to pull it out (you should have one if you're working on you car, but then again you should also have a plug socket)
Sent from my HTC Velocity 4G using Tapatalk 2
I think the special tool hooks under the connector so you don't pull on the plug lead & wreck things.Understand how it works, troubleshoot logically BEFORE replacing parts.
Numerous Mk1 Golf diesels
You need the tool so you don't pull on the ht leads and ruin them. Leads are a couple of hundred a set. The special tool is $12 on eBay. Surely a no brainer?sigpic Camden GTI Performance. VW / AUDI Specialists
