Originally posted by grtuned
View Post
MKIV Golf 2l Water Pump
Totally agree with that point!!! if you fit metal impeller it should also be replaced when timing belt is due IMO. Timing belts and water pumps should be done at same time.Originally posted by Ogre View PostThe probelm with the plastic impellor is that they have reported failure rates at less than 100,000 km's. A good metal (brass) impellor will last the 100,000 kms so that you can be guaranteed that you don't need to do the waterpump early.
Sent from my iPhone using my fingers.
Just noticed that little black box in front of the coolant bottle is making a crazy ticking sound when cooling down the engine it sounds like a valve open and closing.
First of what is this box and does it normally tick from the valve that sits on top with a plug in it and a coolant hose?
---------- Post added 22-02-2012 at 12:59 PM ---------- Previous post was 21-02-2012 at 10:13 PM ----------
just realised it's in the position of 14 in this picture not sure if the fuel pump is in the same position on all cars as this engine is a TDI
now i would think the fuel pump would be in here aswell which i think would be making that clicking noise.
anyone had to replace thiers before and could it make the noise im hearing
I don't suppose you have a link? I can't find it.Originally posted by Ogre View PostJust follow the DIY on the vortex page.
Also, what other parts are needed? IE: Do I need to buy seals etc sepatately? Or do they come with the water pump??
Thanks in advance. Also, mine is a 1.6L AKL engine, and I'm having trouble finding any info, even a decent Bentley/Haynes manual!Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
