Time for an update?
Well i got down and dirty a couple nights ago with the bora and off came the gearbox!
Followed this guide VWVortex.com - Transmission Removal Clutch Replacement diy Quick Version and its pretty much spot on. Note that when seperating the transfer case and gearbox you can expect a flood of transmission oil to spill out. I'd recommend draining the box before doing this to save getting covered in oil... doesnt taste great
Two of the trickiest bits was manouvering the gearbox off after unbolting it and also getting the 6mm allen bolt from out of the transfer case, although not hugely tricky just frustrating (the one buried deep in the drivers side driveshaft, step 21 in the vortex guide) Initially i bought several allen key extension shafts however i broke all 4 that i bought!!! In the end i ended up making my own by welding a 6mm hex head with a drive adapter to the threaded rod from a spring compressor... Believe me, this one will NEVER break!
For removing the gearbox personally i would recommend using an engine hoist to support the engine or having an engine support brace like seen here http://www.lonestarminiclub.com/gall...0/DSCN0648.JPG
It's not completely necessary, the Vortex guide uses a jack to support the engine, however in honesty its not hugely stable like that and could easily slip out of the drivers side mount, especially when your rocking the gearbox / engine assembly to get the bastard out. So between an engine to the face or 5 minutes rigging up my engine crane, i decided on the safer option!
Upon getting the box off i was pretty happy to see the clutch seems quite new. Even though its going to be replaced it means that the rear main seal didnt just look new, it probably is. I'm not a fan of replacing rear mains when they're not leaking as sometimes they then leak! Luckily this means somebody else has risked changing it and won. The dual mass flywheel also looks to be in good nick, not rattly and smooth. Again this is also going though as i have a lightened chromoly flywheel and carbon ceramic clutch to go on
For getting the box back on i'm actually almost contemplating dropping the motor, there really doesnt look like theres much left attached to it other than some cooling lines and a couple wiring looms and being rigged to the engine crane means it might only take an extra 10-20 min vs wrestling a gearbox for the better part of 30m-1hr! Hrmmm decisions decisions.
Next steps from here is to order in the seals for the trans - transfer case, pull the sump to weld in a oil return, put the new clutch on and after that just paitiently wait for my intake, head spacer and a few other bits from C2. Might give them a call monday their time to assess where they're at. Once i've got the final bits from them i'll hopefully have it all running within 2 weeks
I'll update this with pics shortly when i get home from work
Pics:
The damnn 6mm hex buried in one of the shafts
The broken extensions
The solution
Safety first!
Happy days
Pics:
The solution
Safety first!
Happy days
