Brittle vacuum hose
  • Brittle vacuum hose
    Hey yall,
    I replaced my stock diverter valve today with the apr R1 but when I was re-attaching the vacuum hose that goes from the throttle body to the top of the diverter valve it just snapped like a candy cane. I managed to use a bit of hose from my house mates air brush gun as a temporary fix until I can source a new hose or take it to a mechanic, I took it for a test drive boosting it pretty hard and it seemed to hold okay, I don't think there's much pressure going threw there any way. I was just wondering if any one else has experience their hoses getting brittle with age and if anyone knows of a kit to replacing all the suseptable hoses. On a side note I really like the apr R1, I don't get anymore flutter when releasing low boost which I actually kinda liked but I know is bad for the turbo. My car is stock at the moment but I am planning to get it chipped in the near future hence the R1. I am also wondering if a k&n panel filter would increase the "swoosh" noise when I lift off the throttle at all? I know this is a long post but if anyone has any insight to my questions I would greatly appreciate it,
    cheers
    Those pipes don't last forever. A good plan to replace all the Vacuum pipes in one go.
    Depending on where you are in Brissy, you have a few options for mechanics.
    Or go to your local car parts place and get some pipe from them. 4mm inside diameter would be correct I think.
      Thanks for the super speedy reply, I live on the south side of brissy but don't mind travelling a bit to get quality work done at a decent price. I'd also like to add the hose clamps VW used to secure the old diverter valve were impossible to get off without breaking, must need a special tool I guess, but I just replaced them with propper hose clamps from supercheap auto
        You can pick up vacuum hose from Auto Barn for less than $5 a meter...
          Jmac is in Runcorn if that is convenient. He'll have the stuff to do the job, if you don't want to get your hands dirty.
            had exactly the same problem.. picked up some vac. hose from supercheap $2.99 a metre and some awesome little clips from streets auto, gott do the other lines, just a bit dificult to get to and those little vw clips are bitches to get off!
            it's not a hard thing to do so go for it and do it yourself!
            Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
              Thats right
              And Gav you are right it is 4mm mate
              jmac
              Alba European
                I bought 20 metres of silicon off ebay, always need it for DVs and the like.
