Hi All
My timing belt change was going well until It came to tensioning the belt, I had the belt routed around all the components (Cam, Water Pump, Crank, Idler and Tensioner). I went to tighten the tension to find that tensioning the slack had moved the crank about 4 teeth forward, moving nothing else. What is my best solution to make sure that both the cam and crank stay at TDC while tensioning the belt.?
