Hi everyone,
So my project is to slowly maintain while adding some extra HP to my 96 Mk3 VR6. Let me know of some recommendations and what you have done to your own car.
1. Cold Air Intake | 5 - 8 HP increase
This is a proper intake setup. Separating engine heat from entering the intake (made that mistake before :p)
2. Intake Manifold Gasket | 8 - 10 HP increase
This is pretty interesting, I was discussing at work to port out the intake, but I don't think that much hassle is really worth it, so I read about this and thought I would order it in.
3. Stainless Steel Decat 710mm | 8 - 10 HP increase
Replaces the stock resonator allowing for easier airflow through the exhaust, also makes it sound pretty good
4. Techtonics Chip | 7 - 10 HP increase
Something I will probably leave to last as this is something that can potentially blow up my engine :/ especially increasing the RPM limit. I will also work on the cooling system first, install metal thermostat hosing, 70 degree thermostat etc.
Not performance mods but some worthwhile mods, a shield for welding to the sump, to prevent punctures and what not.
Metal intake tube as plastic breaks... Mine has anyway no sake wasting money on another OEM plastic one.
Hope you guys like, not much information but just my little project over the next couple of weeks.
