3. is for the flaps to work as in the recirc ones
4. sounds like the pump in the passenger wheel well ( if you remove the fender liner you will see the pump )
12. sounds like you are talking about the pcv? be ready for a shock when they ask for $150-$210 for a new unit which is also no longer produced, you may find ones that are sitting in stock and also becareful that the early and later cars use a different intake elbow. Alot of the guys run a catch can or just run a hose from block to intake elbow
13. im pulling the original mk3 system out to replace if you want it it yours free
