Give them time, they probably can't afford to invade until I give them more money for VW parts
Mother in Law's - Maroon VR6
Today I fitted up some replacement tail light seals, thank you Stefcio007.
Removed the leads and plugs and fitted new plugs.
Went to fit the leads but they are wrong and for a passat, so getting swapped for correct ones on Monday.
Then I fitted a replacement TCM and tested the heatercore for leaks with a garden hose.
Not one drop of water in the cabin. Think I may be lucky!
I've ordered some T pieces and some hose to modify the coolant hoses to suit an automatic transmission, a lead removal/install tool and a replacement airbag controller.
Once these parts arrive, I will be able to fit, put the car back together and do a road test.
Then I think I'll be doing a gearbox service and replace the sump gasket and plug while I'm there.
Hoping that is all it needs, with the exception of some replacement panels as they become available.
Happy days
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
not in a vr6Originally posted by HaydEn View PostLeads are all the same. Sharan, golf, jetta, passat, euro van and probeMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
These ones have stalks and a much thicker exterior. Look like convoluted tubing. Far too big to fit in the stock plastic engine covers. Sure they may work fine but they are not right for the car.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
I want leads with stalks that fit in the plastic engine covers.Originally posted by stefcio007 View PostMK4 ones fit, I'm running them.
Longer stalks and thicker tubing.
Mine are from ECS, red ones. Solved all my running rough issues.
What do I ask for? Mk 4 bora?Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
I ordered MK4 Golf leads.
Found the ones I bought:
403 Forbidden
Ask them for something that looks like these.Past - '95 VW Golf MK3 VR6
Ended up getting VR6 leads VW Village in Kensington. They are also red, which is a bonusOriginally posted by stefcio007 View PostI ordered MK4 Golf leads.
403 Forbidden
