Hi all, some of you may have seen my baja project floating about the forums.. but more to the point i am purchasing a 1995 mk3 golf with a 2ltr engine to eventually go into a rather modified baja bug.
Now while the engine is in the golf and running i want to do some work to it and get it ready for the buggy, i was planning on going a bit old school and converting back to carb and dizzy. So here are the questions so far:
Just checking but the mk3 is efi right? Im picking the car up in the next few weeks.
I have a 1.6 dizzy from a mk1, will this work in the 2 litre ?
I have a single 45 dcoe and lynx manifold off the 1.6, will this fit the 2ltr and be enough carb ?
Is there anything i will need specifically to convert back to carb?
Has anyone done a draw through turbo setup? Its used on aircooled engines a fair bit and is rather simple in theory, must use a carbon sealed turbo though.
Thanks all, Darren.
Thanks all, Darren.
