Tim's 3 Door VR6 Turbo Build
    The turbo will hit the brake booster . Also the turbo intake will be right next to the brake fluid reservoir .
      Originally posted by anthony--t View Post
      Good stuff Tim! Know that motor has been in the works for a while! Keen to see it come together now.
      Originally posted by declanmk1 View Post
      This thing is bananas
      Originally posted by AKA VR6 View Post
      timmk1banana's?
      Thanks guys it will be bananas hopefully haha.
      Originally posted by browndizzle View Post
      good to see my engine going to good use!
      so excited to see this thing hammer!!
      goodluck tim! always here if ya need a hand
      Thanks Simon I'll let you know if I do. The engine was in immaculate condition so it will make a perfect base for it.
      Thanks Seb I'm aware of the brake fluid reservoir issue and it will be sorted. As for the charge pipe the compressor housing needs to be rotated and moved and will face towards the P/S anyway, I simply put that photo up for illustration of progress thus far.
      How's your VR6 turbo drag car going any more progress from when I saw it a couple years ago?
        This is going to be mental
          Did you go with a t3 or t4 turbo flange?
          Sent from my HTC_PN071 using Tapatalk
            T3 Flange.
            Fitted the MSD ignition today:
              Good stuff man!
              '95 Golf VR6 Colour Concept
                I am DEFINITELY coming over more often to see this take place!
                CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v )
                PAST: MK5 GTI Pirelli + MK4 Golf 1.sick + MK3 VR6 (RIP)
                  Go Timmy go, show them fat ass bora boys how it's done
                  Garage:
                  VR6
                  XR6
                  R36
                    You mean Bora Boy*
                      so sick!
                        Thanks guys it's going well!
                        I installed the 02A shifter box recently and ordered my surge tank.
                        I got a 5L Proflow with dual 380LPH E85 pumps. Should do the job!
                        • #27
                          Lol. If that doesn't do the job; you've ****ed up.
                          Running bigger lines from tank to surge tank/to the rail?
                          • #28
                            Haha yeah big problem if I run out of fuel lol.
                            Running 8an (12.5mm) feed line and 6an (9.5mm) return line to the surge tank. Feed from the main tank to the surge tank isn't critical but most likely 6an.
                            • #29
                              Are you going to run the pumps sequentially or full ball all the time? That is some flow
                              • #30
                                You mean Bora Boy*
                                Nahh isn't there like 3 or 4 turbo bora's roaming around now ?
                                I know the wagga fellars have 2 of them.
                                Garage:
                                VR6
                                XR6
                                R36
