[boot light back to stock, why did I not know about the meaning of the red colour before...]
stefcio007's '96 MK3 VR6 [build thread]
-Front lip re-painted black
-Lower grill re-painted Tornado Red
-mk4 Longbeach wheels
-the badge has been re-sprayed too but with just some basic silver paint
Only issue I had with the wheels is the centre caps won't go on the rear, I'd have to get spacers or stick them on somehow. Only need about 2mm or so extra really.
Yes it sits pretty high, but really happy with it.
[ATTACH=CONFIG]10267[/ATTACH]
Didnt want to have to deal with spacers...Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
Tried some of that Mother's Naturally Black stuff. Seems pretty good, will have to see how long it lasts. Might post some pics.
Finally fixed my PCV issue with a bit of work, now I won't have oil messing up the engine bay.
Replaced oil and filter while I was at it and had it balanced and aligned (it was quite out but I knew that from the start, just didn't think it was that bad)
Replaced the Air Filter a while back and it was a nice improvement. And did get around to wiring the sub power properly as you can see in a previous photo.Past - '95 VW Golf MK3 VR6
They do look similar to them but they are actually called Avus II's.
Longbeaches have a round edge to the spokes compared to your which are squared off more.White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
Thanks.
I was already in the shop buying other parts and I just happened to see it there but not the other one so I bought it.
Only place where it didn't really work well was the door handles. I think it's a different type of plastic. I need to replace those seals anyway. eBay the best place the get them? Found one seller and prices were reasonable.Past - '95 VW Golf MK3 VR6
New parts next week!
I've run into a problem with my passenger side lock. The keyhole turns both ways but doesn't do anything. Locking the car using the drivers side lock does lock the door though. What could be the problem? I'll also not that the keyhole on the boot never worked either but did lock/unlock together with the whole car.Past - '95 VW Golf MK3 VR6
the spade bit in your door lock has snapped
the thing on the left.
buy a door lock from some wreckers and swap em out.
youll also need to swap over the clips from the barrel so that you can use the same key.
theres a DIY somewhere on how to do it.
pretty easy.
i did one of my doorlocks a while ago
nah. i guess olders ones may or may not be weaker.
my passenger one went to.
they just snap s'all
