hello people wondering which wires are the low beam wires that run into the head lights so i can T off from the low beams to my fog lights if thats a bad idea please let me know
fog lights and blinker unit 94 vr6
Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.htmlTags: None
Mate on your headlamps there is a yellow and a white wire. rule of thumb on Porsche ,Audi and Vw the White wire at the headlamps are high beam and the yellow is low beam. If your splicing mate for other lamps do so with a 5 pin relay as you may overload your switch, thats the only dram you can have.
CheersAlba European
Dont have the fogs on permanently with the low beams, as that is illegal.sigpic Camden GTI Performance. VW / AUDI Specialists
very helpful guys if thats the case il wirer it to the relay then to a seperate switch my, is it true the 95 vr6 came with a light toggle on the blinker leverWide Steelies For Sale
Some (i think only overseas models) came with a fog light switch as part of the main headlight switch, you can pick these up for around $50 and upwards on ebay UK and it just replaces your standard headlight switch but has the extra function. You'll find them mostly in the UK as you need to get one for a right hand drive vehicle, lefties are opposite way round.
One of these fellas:
Forever blowing bubbles.
High beam and fog don't mix.Originally posted by Pullstarter View PostI think legally you have to have them hooked up to the high beam AND have a separate on/off switch mounted on the dash from memory
Spot lights/driving lights fall in that category, fogs just need a separate switch. (although it may need to be on with at least parkers).
We used to remaove the 1 stage headlamp switch and fit the dual with some extra wiring on some, there is a Vw part number for this, it was a common ask when we were pre delivering these vehicles along with a string of other goodies.
CheersAlba European
You can connect your fog lights to the main harness plug just behind radiator. You can also mod your original headlight switch so you can run fogs and park lights only or head and fog together. I can have a look on mine for exact pin.1st place Mk3 Standard 08
swweet got it all wired up turns out i already had the fog light switch all i had to do is pull it out
got me self a 12 volt relay followed the diagram on it, very fresh thx again people
