Originally posted by drucejnr
View Post
MK3 Random Thread
Originally posted by xpeesx View PostAttn; Wheel Whores, Question regarding fitment, as I am a wheel noob. 15x7 et42, How would they sit on my mk3?8et25 currentOriginally posted by xpeesx View PostI'm running 15x8 +25 now and the front fit flush and rears are a a little in.
7et42, will poke 30mm less, have 4mm less clearance to the strut.
Mk3 vr is 6.5et43 from memory, guessing 4stud mk3 is like 6et38ish. if that gives you some ideas
Originally posted by Water Boy View Post15x7 et45 will poke less than your current set up! Lower the et number further the guard sits away from the strut. (Out the guard more)Thanks for the help guys. Think I might pass them up. KeepOriginally posted by dylan8 View Post8et25 current
Looking for something else.
MK3 Random Thread
My new wheels are 17s (because I couldn't get them any smaller) and I'm insure if I should go 17x8 or 17x9. Mind you, I've only acquired the faces and need to buy new barrels and lips for this lot /:Originally posted by anthony--t View Postmk3 wheel fitment equation.
A"xB" etC
A= 15,16,17 depending on personal preference
B= biggest number possible
C= smallest number possible (-negatives?)
Abide by the above and you shall acquire many efame and much scene points
Sent from an Asian sweatshop.
9.5 is really pushing it, especially in 17s. Would need as much offset as you can get before it touches anything inside. You'll need to stretch some small tyres and a fair bit of camber to make it work.
Can be done though. I was going to run 15x9.5 on my mk3 and it was going to sit perfect. I'll see if I can dig up some test fit photos and the offset
Sent from my GT-I9305 using Tapatalk 2sigpic
