Originally posted by Smeeeb
View Post
MK3 Random Thread
Yeah pretty much just a carbon look version by Kamei, see how it looks when it arrives, should match up to the stock VR tails well
Originally posted by Peter JonesYou take corners on three wheels, and V8's can't catch you.
Anyone know how hard it is to center my rear axle? I'm pretty sick of my left tyre being chewed up and my right being untouched. It's almost unnoticeable if it weren't for my left tyre being destroyed.
Also, I want a little more rear camber, I've read up on the washer idea? I'd only probably got 1 or 2? Or better to just buy shims? I'm just a little low on cash as I'm saving for Japan in March, but any help appreciated
'98 Golf Mk3 4 Door
Jack car up and support rear sills with jack stands. Be sure you use good stands and support where the little < arrows points downOriginally posted by Blep View PostAnyone know how hard it is to center my rear axle? I'm pretty sick of my left tyre being chewed up and my right being untouched. It's almost unnoticeable if it weren't for my left tyre being destroyed.
Remove rear wheels.
You will see 3x17mm bolts per side where the rear beams mounts to the floor.
Undo bolts just a bit of both sides and with some help from a mate move beam left or right
Be careful no to move it backwards or forwards (This will angle the beam and feck your toe, ride drive its)
Take your time and be careful. Do the bolts up again and slap here down and ride with fat chicks!
On the washer question, go to bunnings buy yourself some washers. I don't like shims because they are plastic and can deform with the heat of the car, whereas shims are metal.
They'll both work the way you want, it's just a case of whether you want something with ajustablity.
Keen as bruzzy, come get your **** already.Originally posted by drucejnr View PostWe're doing the washer treatment to mine when the wheels are built - want some fatness
