Stoked you managed to get them on, makes me wheel more confident about getting my wheels on as they aren't as extreme as these. What ended up being required to fit them, just the 10mm spacers in the front? Definitely an aggressive setup! Are the flares going to back on?
trouble fitting kerscher carmona's 16x9 +15 on front HELP!!
yep 10mm spacers also minor grinding to the front brake carriers . ive tryed putting 15mms on but the just stuck out too much so decided to grid the carriers.the guards require minor rolling and pull but it should be okay with a little bit more -camber. i hated grinding the carriers but had to be done. the rears fit fine they just need a little bit more - camber.Originally posted by anthony--t View PostStoked you managed to get them on, makes me wheel more confident about getting my wheels on as they aren't as extreme as these. What ended up being required to fit them, just the 10mm spacers in the front? Definitely an aggressive setup! Are the flares going to back on?
i just cant stop staring at them
94' Golf Mk3 Vr6
show us a more front on pic!
sorry boys and girls for not keep you updated but I had sent the kerschers to the repair shop to get 1 of them resprayed to silver since it was a weird blue colour so i should be getting the kerschers back from the wheel repair shop today so i can start rolling my guards
Then Picture time as some requested. I still havnt resprayed the car Since its just been sitting in my drive way and some idioot decided to Key the right hand side of the car from the headlight all the way around to the left hand tail light
so im scared to get it respray until i catch that person
I still havnt got my license back since i lost it for a year and only have 141 days , 21 hours ,51 minutes and 43 seconds left Yes im counting down
my rear wheels seem to poke out less then the front wheels since the front has 10mm spacers so im not really sure what size spacers i should add to the rear any ideas ?94' Golf Mk3 Vr6
I wont make it to any meets this year
but up front im already at maximum camber and it clears the fenders suprisingly but i want to back it off a little bit and do abit more fender work and go lower then once im happy with the way it sits ill be getting a full respray by the end of this year if not in january. im going to try and get my old man to machine me a pair of camber shims for the rear ive got a few designs in mind . ill see which one suits my car better . im not sure how much it would need but untill it clears i guess. i noticed that my tie rods hit my sway bars i think it was so ill need to get a tie rod end flip kit like this Tie Rod "Flip Kit" MK1, MK2, MK3
94' Golf Mk3 Vr6
...... how much camber you running/want to run/if at all, front and back?
