Good stuff Pete, I am looking at doing that for my mk3.
Thread that combines all my car threads
now that my maf is further away from the throttle body it seems to run a bit richer and has a lower idle
anyone care to explain why???Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.html
thanks dude but its definatly centered or the same as i measured everything to match upOriginally posted by Mrk_Mickey View PostPete it looks like the maf sits further out of the centre of the pipe than it should (reading air flow, hence best to put it directly in line?)...that could explain things maybe?
its not really a problem its actually gives me a bit more punch just wondering why technically?
if anyone has any knowledge on how a MAF works chime in.Wide Steelies For Sale
a mass airflow meter works by heating up a thin metallic wire to quite a high temperature. The difference in voltage potential across the wire is measured as a rate of change as the air flowing through the inlet is used to determine what mass of air is passing through the cross sectional area.
basically. wire gets hot. air going in cools it down. as the hot wire gets colder, the voltage of the sensor changes --> change in mass of air.
The grid and shape are really all quite important for the maf to work within factory parameters87' MK2 GTI
13' MK7 TDI
cheers jayjay very educational, you learn something new every day
factory parameters.... hmmm i dont think my car is anywhere near that anymore haha
James your a legend
the car was looking seriously tough Pete
Good work!
FOLLOW US ON FACEBOOK
Sorry if you see any white stains on your car Pete.
cheers for the coments guys im stoked!!!
il be putting these plates on soon AVR 666 black with white writing should look tops
next mod on the list is a bigger exhaust
