Hey Guys,
I think my ignition switch is starting to play up. Sometimes it take a few turns of the key to start and I've noticed that if I turn the key and then turn it back just a bit it fires up. It also seems to stall when I go to break and that can be a bit scary. This happens randomly but usually doesn't occur again after it has happened.
I'm hoping that if I put in a new switch things should go good again.
I've located the plug and switch on the steering column and my brother; an ex auto electrician; found that the wire to starter pin seemed to be loose. We tried to jam a little screw in there and that seemed to help with it getting a better contact but it still stalls sometimes.
I the just wanted to know if I could do the replacement without having to take the steering wheel off?
I'm reluctant to let the missus drive the car as I don't want it to shall on her while out driving.
Anyone else experience anything like this or has any insight?
